JIMNLIN
Aug 19, 2018Explorer III
1. A ST205/75D14 at 50 psi is a load range C bias ply tire which has a narrow profile. The D in that position is a bias ply designation.
You put a ST205/75 E load range probably radial at 80 psi which has a wider profile and is way too much tire for replacing a C load range tire.
Only the trailer mfg know why they chose that particular tire.
2. its not a wise idea to cheap out on tires for a trailer that may see lots of highway miles.
