rhagfo
Aug 22, 2014Explorer III
KD4UPL wrote:
He didn't ask how to upgrade the GVWR, he asked how to upgrade the payload capacity.
I'd find out what else was different besides the axle gears between the 7,200 and 8,200 models. If it's the exact same axle and brakes the difference may just be in higher rated tires. I hope you at least have LT tires on it and not P tires.
Air bags will help if the rear is sagging. Bigger better brakes are always a good idea. That's about all there is to upgrade for no more capacity then you need.
Otherwise, find a nice 2500 sub.
Payload is directly related to GVWR, so you would need to increase GVWR to increase payload.
Gear changing doesn't increase GVWR, it will increase GCVWR, meaning you can tow more weight with lower gears, IF WITHIN GVWR and axle ratings.
Best thing for OP is to get a Suburban 2500!
44,068 PostsLatest Activity: Jun 19, 2026
