rhagfo
Aug 24, 2014Explorer III
intheburbs wrote:MVH1 wrote:
One way to help stay within the limits of the vehicle is to move some of your weight to the back of the trailer. This will take some of the weight off the tongue. I would distribute some of the weight in the trailer and then go weigh it.
I did this when I was towing with my half-ton Burb. Problem is, if you take too much weight off the tongue, the trailer is less stable and more prone to sway. I ended up bending the plate on my hitch because I had my sway brake cranked down so hard. Wouldn't recommend it.
X2
I would rather see OP over weight and stable than under weight and swaying all over the place.
VERY BAD suggestion!!!!!
44,068 PostsLatest Activity: Jun 19, 2026
