Baja937ExplorerApr 13, 2015Increasing 12VDC Shower Head OutputWhen running off your fresh water tank and using the 12VDC Water Pump, is there a shower head available that could increase the pressure and flow when using shower? Or will you still have the weaker ...Show More
Related Contentincrease shower water pressureQuick connect exterior shower hose doesn't connect.Oxygenics Fury RV Handheld Shower head --COLD dripINCREASING lpg capacity ?Generator output voltage
