Baja937ExplorerApr 13, 2015Increasing 12VDC Shower Head OutputWhen running off your fresh water tank and using the 12VDC Water Pump, is there a shower head available that could increase the pressure and flow when using shower? Or will you still have the weaker ...Show More
wanderingbobExplorer IIMay 12, 2015Ask any firefighter , increasing pressure lessens volume ! Do ya want more pressure or more volume ?
Related Contentincrease shower water pressureQuick connect exterior shower hose doesn't connect.Oxygenics Fury RV Handheld Shower head --COLD dripINCREASING lpg capacity ?Generator output voltage
