NC_Hauler
Mar 19, 2016Explorer
otrfun wrote:IDoMyOwnStunts wrote:Hhmm . . . Gotta wonder. Did they mistakenly put a gasser 3500 tire pressure sticker on my Cummins?
Not all Rams are 80 front. My yellow sticker says 60 up front, but my axle only says 5500 lbs, probably because it's not a diesel. Rear is 80 for SRW 7000 lb axle.
Does make you wonder...I've had the 2010, 2012, 2013 in my sig, and all three placards stated 89 psi for the front and 65 for the rears...I've looked at 2016's , and though the one's I've seen had Nexen tires instead of the Generals, the psi recommendation for the front is 80 psi and rears 65 psi...
On my 13', CAT scales had me at 5280# for front axle (steer axle weight)
