APT
Jun 10, 2013Explorer
What transmission does your van have? I see no reason to limit your tow rating to 80% of MFR rating. You have plenty of payload, axle rating, frame, and receiver should handle 1000 pounds of TW. I really only see performance being subjectively unpleasent at time. 3V 5.4L has decent torque. As long as you have a 5 or 6-spd trans, 3.73 should be good for 6500 pounds loaded. That should get you into some decent 5000-5500 pound dry TTs.
Another option is to change the rear differential gearing. Going to 4.56 will really help while towing and around town for about $1000 ($500 for gears installed, $500 for tuner to correct the trans shift behavior). If this van is not used for much unloaded highway driving, I'd do that and look at RVs under about 7k pounds.
44,067 PostsLatest Activity: Jun 02, 2026
