Yak
Nov 30, 2014Explorer
Home Skillet wrote:
Look at your valve stem, that will determine what system you have.
The band mounted sensors use a rubber valve stem.
Stem mounted sensors have a hex headed nut holding the stem on.
The sensors run around $50 each. To reset the sensor will require the vehicle to be driven for about 5 miles.
OEM is always the best.
Ford now has 3 types of sensors
http://www.oreillyauto.com/site/c/search/TPMS+-+Sensor/05430/C0337.oap?make=Ford&model=Explorer&year=2006&vi=1432146
44,056 PostsLatest Activity: Jan 12, 2020
