Horsedoc
Dec 05, 2022Explorer II
Insert pins
Loaned my Ram 1500 to a relative the other day and upon return the insert from the hitch was in the bed but the pin was missing. I had a pin with a hole that a clip key slid into. I was pretty sure ...
Cummins12V98 wrote:
You need a straight pin without the curved end. Problem is the curved end will cause an egg shaped hole in the receiver. This has been discussed thoroughly on the TDR.
