raden13's avatar
raden13
Install locking gravity water inlet (Video)
Hello fellow campers. I replaced the gravity water inlet on our trailer with one that locks and thought I'd share the process. I wasn't too fond of having to cut a bigger hole in our trailer, but it ended up not being that big a deal and I'm happy with the results. Enjoy
https://youtu.be/TELGdiu_VGM
  • romore wrote:
    For some reason I can't open your link. The door hinge broke on ours, I found one that is designed to slip into the hose and siliconed it into the opening. It doesn't lock but works for me.
    Not sure what happened. I just edited the link and it should be working now. Good luck.
  • For some reason I can't open your link. The door hinge broke on ours, I found one that is designed to slip into the hose and siliconed it into the opening. It doesn't lock but works for me.
