- bobndotExplorer IIIOn my slider , I used baggage door latches with those famous #8 ss screws :) in the upside down position. When not in use, the flipped up out of the way. They flip down when needed. We used a small fan to help dry the towels and never felt the need to use a towel bar.
stainless baggage door latches - WanderlostNomad IIKip, how many towels can you put on one of those towel bars? We need space for four towels to hang and dry at once. That can add some significant weight, especially if one is inclined toward the really thick, fluffy towels - as are we.
We're modeling our sliding door towel rack like we have in the old Itasca Sunrise, except with wood dowels instead of the moving metal racks. Since it will be all wood, it will be heavier, requiring more support than just screws. WLToo will be using the anchors. - GrandpaKipExplorer IISo far, in 3 campers, I have installed towel bars and hooks using only #8 SS screws in walls and doors. Not one has ever pulled out. Lots easier than mollies or anchors.
downtheroad wrote:
Thin wall Molly Bolts
Home Depot, Lowe's
But, once you mount the towel bars, how are you going to slide the door if it is a 'pocket door?'
It's not a pocket door. It slides along the wall by the toilet to close off bedroom and bath. About the only place to put towels within reach of the shower. - wecamp04Explorer
westend wrote:
If you can use a towel that isn't neatly folded over a bar ( I can), try a towel hook. They are easier to locate and install.
What we did got 3 two double hooks and one single works for us - westendExplorerIf you can use a towel that isn't neatly folded over a bar ( I can), try a towel hook. They are easier to locate and install.
- 12thgenusaExplorer:S
- downtheroadExplorerThin wall Molly Bolts
Home Depot, Lowe's
44,066 PostsLatest Activity: Oct 04, 2013
