bobndot
Apr 11, 2017Explorer III
http://forum.expeditionportal.com/threads/128148-Building-an-over-dinette-bunk
i also saw a fabrication made from pvc tube.
It was set up using the dinette seat as the base platform to support the freestanding weight of the homemade pvc bunk frame.
If you remove the dinette cushions that will leave the exposed plywood which would act as the foundation to support it.
I would think its possible to fabricate some kind of "flat' hardware (part 1) that could be mounted to the dinette seatback and left in place, covered by the cushion when not being used as a bunk.
To make the bed, remove the cushion, slide part 2 of the flat hardware that is part of the bunk framework. You could use the dinette cushions for the bunk.
44,066 PostsLatest Activity: Oct 04, 2013
