HMS_Beagle's avatar
HMS_Beagle
Explorer II
Mar 03, 2013
Installing a Fantastic vent with proper sealant
I removed my air conditioner on my BF10.4 and plugged the hole with a Fantastic vent. As a "self appointed sealant expert" I thought I would take the occasion to troll and pontificate further on roof sealant. The Fantastic vent is - well, a fantastic product. However the instructions with it recommend using their PE foam gasket and then smearing the outside with silicone. In my opinion this is close to the worst way to install the vent.
I cleaned and prepared the area, taping off around the flange:
I am using 3M 4000 UV, available at marine stores and online. This is a polyurethane medium strength sealant with a working time of about 30 minutes and a cure time of 24 hours. To clean the surfaces prior to bonding I am using LPS Presolve, a great spray degreaser/adhesive remover which is harmless to most plastics. You could use any non-residue degreaser, just make sure it does not attack the surfaces:
I have taped right up close to the flange all around, close as I can get without going underneath:
