joeshmoe
Aug 20, 2017Explorer III
GeoBoy wrote:
Joe, I read the instructions for the Roughneck gasket and the adhesive side is supposed to go to the AC pan not the roof membrane.
Hmm... Not sure. The way I read the instructions, it's designed to go on the roof side.
anutami wrote:
When I ordered mine with the mach 8 9200 Btu ac and found they installed the 13k model instead they also used a sealant and took about an hour to replace. I found using a credit card was the easest thing to break the seal. Apparantly the dealer installed the ac. Because their were about 30 screw holes whete the standard vent had been. I used dicor to be on the safe side.
Yeah, the hardest part was getting the old one down and the new one onto the roof.
Did you use the gasket that came with the A/C, or did you get one with the adhesive? The existing bolts I have are apparently to prevent shearing in the case of movement.
Note the oil leak which caused the roof to bubble
44,056 PostsLatest Activity: Jan 12, 2020
