donn0128
Dec 12, 2013Explorer II
Depending on the brake controller you are using, the easiest is to also buy the wiring harness from the brake controller manufacturer. Then it becomes plug and play. You will need a 7 pin connector on both the trailer and rear of the SUV. Wiring then is per the Bargman diagram found all over the internet.
