fmattox73
Jan 03, 2014Explorer
I finished installing the rest of the brake system yesterday (1/2/14) including the wiring back to the controller and all is well. The brakes work very well and were easier than installing the controller. My particular trailer already had the brake mounting flanges and the Brake Wire (Blue in this case)in the frame and all I had to do for the wiring was to pull it out from the split wiring cover and run it to the brake solenoids on each side of the trailer and then ground one side of the solenoids to the frame. After strapping down the brake wires that I had run, I went for a test run and made a few adjustments to the controller, then tried a couple of panic stops from 50/60 mph and they work very well.
Frank
Frank
