LIKE2BUILD wrote:
Has anyone installed the Ram 5th wheel prep kit part# 82213980AB in their 2014 or newer Ram 2500?  We're about to purchase a 5th wheel and I want to use this for my attachment points in the bed.  My truck didn't come with the kit pre-installed so I'm going to tackle this myself.  I've seen on other forums the kit comes with good instructions, but I'd like to see a video just to make sure I'm comfortable with it.
Thanks,
KJ
I did it last fall. Took about 4-4.5 hours working by myself, including the electrical outlet in the bed. The OEM bed bolts were really hard to remove do to the locking stuff they used. Two people would be able to do it much quicker.
You have to remove the bed bolts and one side and loosen them on the other side, then jack the bed up on one side as a time to place the pucks into the mounts that are on all the frames. I used a board from a trolley floor jack to raise the bed. My SB has three mounting bolts on each side.
Drilling the big holes in the bed is scary. I had to order the hole saw, as it is not a size that the box stores stock.
https://www.amazon.com/gp/product/B000E8FP6C/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1I drilled the first pilot hole and then use a bent piece of wire to check the calibration of the location, and made a slight adjustment of the three other locations based on that finding.
PM me if you want I will give you my phone number to talk.
I did not install the gooseneck hitch.
I really like my B&W hitch. The latch mechanism is the best there is available.
Chris
