freetime58
Nov 30, 2019Explorer
Simple install, tap into the top center clearance light as previously mentioned, the camera will be active when your running lights are turned on.
If you want to use the camera while camped as well, you'll need to tap into the 12v circuit in your trailer that always receives power from the onboard battery, any 12v light will do, you probably have one close to where you would need to mount the camera on the outside. You would need to take the monitor with you into the trailer and need a 12v power source close by.
I see why some folks (with no rear window in their unit) might want visibility out the back while camped.
