enblethen
Oct 23, 2017Nomad
I would start by measuring the distance from the frame to the ground. Get a jack that the mid operating point is about one half the distance. If you get a jack that is nearly maxed out, it will be wobbly.
Bal jacks would be a good choice.
Bal
Since the bolts are only to hold jacks in place, there is no reason not to use the self-tapping screws. Make sure you use the correct size drill bit.
Bal
44,070 PostsLatest Activity: Sep 18, 2026
