Gdetrailer
Oct 23, 2017Explorer III
plasticmaster wrote:
With the frame being a rectangular tube, how could I drill a hole and get a bolt and nut in there to mount it? I may have to use self tapping screws.
You would have to put a steel tube to create a spacer through the frame tubing otherwise risk crushing the frame tubing.
Basically would have to drill oversized holes to accommodate tubing with a large enough inside diameter for your bolts to fit through.
I would not attempt to bolt through a tubing frame without reinforcement like a spacer.
Personally attached jacks are over rated, while they are a short cut, they often get damaged or like around my area heavily rusted from road salt..
I bought 4 auto scissor jacks and modified them by welding about a 8" long piece of "C" channel to the tops. The "C" channel is wide enough to fit around the trailer frame and the 8" length keeps the jack from "rocking" back and forth.
I modified one of the jack handles by cutting off the offset part and then I can use my cordless drill to wind them up and down in a hurry.
Yep, I do have to remove and store them, but they don't rust up or get damaged.
4,000 lb auto scissor jacks typically sell for $20 each or you can often get deals at your local auto scrap yard..
44,070 PostsLatest Activity: Sep 18, 2026
