Mike_Stanbro
May 04, 2014Explorer II
kerry4951 wrote:
Same system works well on Arctic Fox. Ive been using this method for the past 2 years. Works well when towing.
And here I was thinking I had figured something out that no one else had. I swear, I spent the better part of three days searching all the forum archives looking at how other people had mounted their steps. Did you post a picture of your setup before? If so, I sure was not able to find it.
I see that the GlowSteps are mounted on the outside of the OEM step brackets such that the just the ends of the clevis pins are bearing the weight. If you switch the long and short sides of the struts like I did, it will likely fit inside the brackets and be that much stronger; however, the OEM step would not fit. I decided I was never going to use the OEM step so that was not a concern for me.
44,070 PostsLatest Activity: Jul 21, 2026
