- rbpruExplorer III have used the 3M Command products many times, unfortunately over time, two of them, one small and the other large, pulled the wall paper loose from the wall and required a screw backup. The remainder under the same load held quite well.
I suppose it is indicative of the wallboard construction but also something to be aware of. - bailer6334ExplorerI bought a over the door hanging towel bar for 3 towels. Cost $18 at True Value Hardware.
- Doug33ExplorerWe just use the individual command strip hooks and they work well.
- Need-A-VacationExplorerJack,
Do you happen to have any pics?
Great ideas everyone as I am looking to install an extend a shower curtain rod and have been hesitant to do so! Lol
TY Vin for posting this question! - bg71361ExplorerHollow Wall Anchors
http://monsterfastener.com/item/hwas-117?gclid=CKqTpImjzscCFcEUHwodKmUJAQ
Click here - Dick_BExplorerThreaded anchors are another option. Put some glue on the threads and let it dry before attaching anything. Use smaller screws than specified and put some candle wax on the screws so they go in easier. If you have kids, who tend to abuse things, use molys!
- Road_RunnersExplorerFifteen years ago I screwed my towel rack to the bathroom wall using toggle bolt anchors. This rack has carried two towels all over the United States and Canada. Never had one bit of a problem. I don't have to worry about them falling off and taking portions of the wall with them.
- coolmom42Explorer IIA lot of people here use 3M VHB tape for holding things. There are different types, widths, & thicknesses available. I got some on Amazon to hold on a piece of car trim, and it works great.
- BumpyroadExplorer
NanciL wrote:
My method, if you are handy:
Cut small backing plates out of thin wood, and then route the edges.
Stain and polyurethane them to match the wood trim of your trailer.
Drill two holes in each and use countersunk tiny brass screws.
The screws are only to hold the plate to the wall which I glue using a good grade glue, and should not penetrate through the wall more than a tad.
The next day I screw the towel rack, toilet paper holder, etc to the backing plates.
You end up with a custom accessory that matches your trim.
I have done this with various items all over the trailer, and they have stayed put for over twenty thousand miles and six years now
Jack L
I did this in the S&Bricks to make a solid mount for the toilet paper holder. made it out of a Plaque that I got at the artsy/fartsy store and was able to anchor that to a stud and then mount the tp holder onto that.
bumpy - NanciLExplorer IIMy method, if you are handy:
Jack L
44,070 PostsLatest Activity: Jul 26, 2026
