pcoplin's avatar
pcoplin
Explorer II
Apr 06, 2015
Insulate windows
I have an older Lance with the front window, and two side windows. What's the best way to insulate the cabover windows?
Should I just cut some silver insulation to fit the windows? I also heard about insulated drapes?
Thanks for any input!
Paul
  • Two pieces of identical solid foam insulation with a cut-out in the center to be able to see outside.
    In between the two pieces of board, I used heat shrink self stick storm window wrap and sandwiched it in between the two pieces of board. I used some glue to hold the two pieces together.
    After seeing that everything fit nice, I painted it .
    This particular piece stays in place by cutting it snug to allow the emergency handles and top of the valance to hold it in place.
    On the other cab-over windows, double sides tape could be used .
    It seems to work very well with no condensation in nigh time temps down to -30F. My non slide TC warms up to 70-75F using the furnace . An electric heater keeps it warm enough (60F) for daytime use.
    I cover the door using an insulated drape . That helps a lot being those doors leak a good amount of air.
  • When I made the new curtains in our camper I used reclaimed upholstery fabric, made a double sided curtain and placed the silver covered bubble insulation inside. Attached to windows with velcro. I made the curtains large enough to fit the metal frames of the windows.
  • We've cut-fit Styrofoam insulation to fit windows frames when RVing at -40.
  • Hi,
    I use Insulbright installed over the frame and held in place with industrial velcro.
