Jframpey
Oct 20, 2015Explorer
Insulating the Belly of my TT
I’m interested in bolstering the insulation of my travel trailer… preparing it for 4 season camping. The walls and ceiling are fine - I just need additional insulation under the floor. The holding tanks are suspended beneath the floor in the void between the frame members. There is wiring, water lines, and gas lines traced thru this space. whatever is used will be exposed to the elements from below- spray from the road, high wind… etc. I’m entertaining a couple of options…
1) After all of my modifications (running a few more wires and plumbing - spraying a thick layer of foam up onto the underside of the floor encapsulating all of the wiring/plumbing. A drawback of this method is that Jayco depends on maintaining a cavity thru which warm air is circulated (although inefficiently) to warm the floor and the plumbing in the void space. A 1/4” membrane called coroplast forms the lower barrier to weather - this is screwed to the frame… not an airtight seal!
2) The other option is to use 1” foam board placed in the void - leaving a 2 - 4” space above anchored with screws appropriately and spray a thinner coat of foam to seal the space…leaving the void above to allow air to circulate.
Which method do you recommend? - which foam product will best stand up to this environment? Do I need to coat the foam to protect it? If so what type of paint/coating is best?
The holding tanks hang well down into the void - approx. level with the bottom of the I beam frame… currently the coroplast lies snuggly against the tanks - I plan to put heating pads on the bottom of the tanks. Can I spray foam directly onto these pads - Maybe 1” thick?.
