Bedlam
Sep 16, 2020Moderator
Are you thinking about a lip on the leading edge of each step or more of an open grate design? I agree it would add to traction but it would also make barefoot and sandal use uncomfortable. If you have pets, I doubt they would like an open grate. Am I not understanding this?
It used to be the case that scissor steps would have to be stowed, but many people figured out a way to mount them so they did not have be removed. Torklift even sells an accessory for their stairs so they stow in place. I use the Revolution steps on my side entry, so they are always ready to deploy and my application required six steps to reach the camper entry. My setup is taller than most, so I am lucky there is a modular system that cam be put together based on the height required.
Adjustable feet make a big difference with stability on uneven ground. I am on my second set of stairs with adjustable pads on the bottom. Prior to this I used to shim the bottom bar on uneven ground to keep the stairs steady and from twisting under weight. Adjustable feet also allow for finer height adjustment if you need a half step height rather than full.
