_DJ_1
Jan 19, 2014Explorer II
Interesting info on F250/F350 rear axles. UPDATE 01 24 14
Made a trip down to the parts counter to see if there is an actual difference between F250 and F350 rear axles.
Well, it depends!!!! Ford uses two different diffs. Sterling 10.5 and Sterling 11.5. My first assumption was the 250 gets the smaller diff. Not so. It depends on the engine!! F250 and F350 both get the 10.5 if equipped with gas engines. F250 and F350 both get the 11.5 with diesel power.
Interesting is that they both have the same GAWR. So why have an 11.5 which weighs 100 lbs more than the 10.5? Higher tow rating which the diesel is capable of. So it really doesn't matter which one if you are just hauling a TC.
BUT.....he said that is not cast in granite!! He has seen gassers come through with 11.5 and diesels with 10.5. The only way to check your specific truck is a build sheet or axle tag.
So I guess I'm just as confused as when I started out!!! Seems they would save money to just build one diff for 250/350 like they used to!! :@
