Bedlam
Jan 19, 2014Moderator
The SRW Ford diesels and larger gasoline engines use the larger Sterling axle. The smaller gasoline engine uses the smaller axle. The specification page muddles this fact which leads to the confusion. It is done strictly for cost saving when you buy the base engine.
DRW uses a different axle if you have a Ford - Dana 80, if my memory is correct.
