jimh425 wrote:
Photomike wrote:
jimh425 wrote:
Kayteg1 wrote:
This is water-based, cheap sealer, design for saving money while painting new drywall. When you apply it over lacquer or vinyl it will peel off at alarming rate.
What kind of RV has lacquer or vinyl walls?
Many have vinyl walls as the wall board that was used was covered in vinyl.
How about naming one? I've never seen one.
The Northern Lite I had used a vinyl covering on the wall board material. It was a thin board with a wrap around the board to give it the texture pattern. Several of the Bigfoot's that I have seen used the same wall board. Also many trailers use the same board.
