greenno
Jan 28, 2023Explorer
I swapped out my lead/acid battery's last year for some LifePO4 cells ( Lithium ) and added an inverter so I didn't need to run my generator for short periods of time like using the micro or to brew up some coffee in the morning.
I purchased a Windy Nation Verta Max 3000w Pure Sine Wave inverter and it works great for what we need it to do. Works great for the times we needed it. Probably wouldn't use it for the AC unless I only wanted to run it for 1/2 hr or so and was able to charge back up easily. nice option to have if installed correctly.
I have a AF990 camper and was able to mount my inverter back in the generator compartment and use the existing wiring to remotely turn it on and off from the galley switch station.
Also have a switch to isolate the inverter and generator so they can't operate at the same time.
