StirCrazy
Jan 29, 2023Moderator
otrfun wrote:
Choosing a capable 2000w inverter is important. Not all 2000w inverters are created equal. Although most inverters can supply their continuous current rating, many fall short providing suitable amounts of inrush current. Inrush current is necessary to successfully start a/c units and microwaves. Unfortunately, very few manufacturers provide inrush current specs for their inverters.
Good luck!
inrush and starting current are the same, just different names depending on the type of equipment. in rush covers any time a electric componant temporatly draws more power when you turn it on, in a motor it is generaly called starting current. every inverter I have seen lists this as peak power. and its usaly a couple K watts above the rated output. for example the renogy is a 2000 watt inverter continious with a peak of 4000 watts that will handle anything on a rv but maby not two large power users at once.
Steve
