otrfun
Jan 31, 2023Explorer II
pianotuna wrote:I believe you're talking about the current encountered on the INPUT of the inverter when it's connected to a power source without first precharging the inverter caps with a resistor.
I can tell you that inrush on a 1000 watt psw inverter is high enough to blow a 30 amp fuse. And that is with no load. DAMHIK
Yup, been there, done that--lol!
Note: This is not to be confused with the inrush current produced on the OUTPUT of the inverter---which is the topic currently being discussed.
