BurbMan wrote:
Sandflea28 wrote:
....and built a short 1ft adapter with 2 male plugs on it....check with an electrician....and ASK how to do it so it is SAFE....
You should take your own advice....this is definitely NOT the SAFE way to do it. A better idea would be to run your shore power cord into the truck bed and plug it into the inverter rather than try to backfeed the TT with a "suicide cord" with 2 male plugs on it.
Even if you don't hurt yourself with the suicide cord, backfeeding pulls all the power used by the trailer through a 15 amp outlet.
