BB_TX
Sep 12, 2022Nomad
Battery is charged by the converter, not an inverter.
And no reason to ever disconnect the battery via the disconnect switch. It doesn’t disconnect everything. If you really need to disconnect the battery for some reason then lift the negative cable.
Forget the ON and OFF labels on the battery disconnect switch. Those have long been a point of confusion. If you can pull the red handle out, the battery is disconnected. If you can’t pull the red handle out, then the battery is connected.
