CA_Traveler
Sep 12, 2022Explorer III
Doesn't your res refer have a inside on/off switch? Turn all disconnect switches to the on position and leave them there since you are apparently a pedestal to pedestal traveler. Battery corrosion on a 2022 battery suggests it's bad or has been over charged. How do you know it's not being charged? You could have blown fuse or tripped CB. Have the batteries load tested to determine if good or not. A digital voltmeter is your friend.
Post make and model of your "inverter". I would hope a res refer would be powered by the pedestal when plugged in and inverter otherwise, but maybe not. Get the RV working then the truck.
