nickthehunter
Sep 13, 2022Nomad III
BB_TX wrote:
...And no reason to ever disconnect the battery via the disconnect switch. It doesn’t disconnect everything...
opnspaces wrote:
... As stated if your disconnect is not a knife switch that you lift to disconnect then it is not a true disconnect...
So y'all seem pretty confident that every trailer manufacturer wires their disconnect switches (the red one) the same way - every time, every vehicle, no exceptions.
That however is an over generalization. Mine turns off everything; absolutely nothing remains on. It is simply a battery, the switch, the one and only wire between them, and downstream breaker blocks; and it came wired from the factory that way. I highly doubt mine is an anomaly.
The last trailer I had worked generally the same way, except it had a fuse in the line at the battery which you pulled out to cut all power (it had no disconnect switch).
