nickthehunter
Sep 13, 2022Nomad III
The converter (not inverter) in the TT should be able to charge a dead battery. The truck will charge the battery if you drive around for about 2 years (in other words - not going to happen). You need to check your converter to see if it is working properly. Secondly, you can’t charge the battery from the inverter. That is a losing proposition - your trying to recharge the battery from battery power. The only way to recharge the battery as while being plugged in.
Being unplugged and operating off the inverter will kill the battery in about 1 day.
