CA_Traveler
Sep 13, 2022Explorer III
From what I found your inverter does not also include a charger. As such it has nothing to do with charging the battery but it can certainly discharge your batteries especially when connected to the res refer. For example a 2A 120VAC refer will cause the inverter to draw 22A from the battery. Battery discharged overnight? Certainly possible. Perhaps your battery is to small to support the refer overnight. What is your battery size, type and how many?
Find your charger and check fuses, CBs etc. 120VAC on the input? Should be 14VDC+ on the output. What is the make/model of the charger. Have the battery tested.
