Thermoguy
Sep 13, 2022Explorer II
You should also get a meter and check your batteries or battery. This is helpful when troubleshooting battery issues. You can also take them to be tested, if you overcharged them, or depleted them, then you could have a bad cell and they need to be replaced. There is lots of good info on this site and the web on living on 12v power. You should take the time to look into that. It seems lots of people don't understand the battery is not a continuous source of power and using it until it stops working is bad for the unit and can take a battery that could last 5 years to one that lasts less than a year. A battery that is very corrosive, could be a sign of improper use or charging.
