qttire1ExplorerSep 12, 2022inverter not charging the battery2 Questions - On our 4th TT and stepped up to a 2022 mesa ridge last year. First TT with a inverter. Only been able to take it out 2 times. Had it hooked up to our house on a 30amp while not traveling...Show More
dodge_guyExplorer IISep 14, 2022Without knowing anything else, from your description, it sounds as if the disconnect switch is labeled backwards!
Related ContentInverter Bad?Inverter charge battery?Inverter installInverter to charge batteryBattery Charging
