brianfowler wrote:
I recently aquired a small inverter generator (900watt) to keep my batteries charged in my 19' Passport travel trailer. The generator will power everything except the converter. It was tripping into overload and it took some playing around with breakers to figure out the culprit. The genny will run the hot water heater no problem, but not the inverter, the only thing I wanted it to run. Does the converter draw that much power? Or could there be an issue with my converter?
Very unlikely your charger is drawing that much power. For example IF you have a 50A charger it will draw about 5.5A AC which is well within the gen capability. I would guess your charger has less than 50A capability.
Are you sure the gen is a inverter gen and are you sure it's a pure sine wave (PSW) gen? If it's not PSW your charger may not "like" your gen power and trip the CB.
