drsteve
May 24, 2018Explorer
Deano_1 wrote:
Hello,
On our camper last weekend, we noticed when plugged in to elecric, the invertor keeps turing on and off. Very frequently. We going to camping this weekend and it's supposed to 85-90 degrees. Any ideas what is going on?
Thanks!
An inverter turns 12v battery power into 120v AC for camping with no electric hookups. Do you mean the converter, where your fuse panel is? If you hear the converter fan running, that usually means it is charging the trailer's battery.
Check the water level in the battery. If low, add some distilled water. If you have a meter, test the battery's voltage when not connected to the trailer's system. Should be at least 12v, a full charge is 12.8 +.
44,067 PostsLatest Activity: Jun 05, 2026
