MicahDD's avatar
MicahDD
Is 1/2" nose high towing an issue?
We have a smallish TT and today I installed an Equalizer WD hitch. Because the tongue of our TT is quite a bit lower than the receiver I have the longer, lower shank that Equalizer suggested. Problem is that when that shank is installed ground clearance between the shank bottom and the road is about 5"... pretty tight IMO.
So I tried the standard shank that came with the Equalizer. With the hitch head assembly on the lowest setting parking-lot measurements show that the TT tows about 1/2" nose up, measuring from the front of the frame to the road vs. back of the frame to the road...
With the hitch head assembly on the longer, lower shank it tows about 1" nose down. But now I have that low-clearance space.
So what's better? Nose up by 1/2" but with ample clearance between the shank bottom and the road?
Or nose down by 1" but with only 5" clearance between the shank bottom and the road?
Any advice is REALLY appreciated, we're leaving to tour America in 2 days and I'd like to do whatever is going to cause the least hassle on the road, thanks!
