MackinawMan
Jun 08, 2013Explorer
Micah, just an FYI, we also tow with the Equalizer brand hitch. Our setup in the end is not quite 1/2 an inch "nose high" as well. Between our 1 ton F350 sitting up so high, and the fact that our Jayco Eagle has the coupler on the underside of the A-Frame, I would need to order the special drop shank that is longer than the standard one as our hitch head is currently bolted as low as it can go on the standard shank that came with the hitch.
I'm not spending $100 (or whatever it was, it wasn't cheap) so I can drop the nose of the TT down barely 1/2 inch when it tows great.
I noticed no difference between it being slightly noseup than when it sat level before. We had put new rims on the truck which resulted in me needing to change the hitch setup. It tows just as nice slightly nose up as it did when it was level.
FWIW
FWIW
