Atlee
Jul 16, 2019Explorer II
sgfrye wrote:SoundGuy wrote:
WFCO's 8955 is no different than it's ever been, mine never charges beyond ~ 13.7 volts, turned it off and instead use a stand alone CTEK charger that does a proper 14.4 volt bulk charge.
yep our wfco 8955 never charges past 13.7 either. when it dies i will upgrade but because we don't boondock or dry camp it has served us and the 2 cheapo wally world 12v deep cycle batteries ok... our fridge is residential so xantrex freedom inverter and the 2 12 volts have been all we needed on longer road trips.
I didn't wait for my WFCO converter to die. I replaced it less than a year after I bought my 2017 J Flight 23RB new. Replaced it with the Wildkat 4655L M(ain)B(oard)A(ssembly). The L means it has a jumper so you can charge Li-on batteries. It's powered by Progressive Dynamics and is an easy replacement kit. Got it from Best Converters. It comes with the pendant that shows, at a glance, at which level it's charging, Boost, Normal, Maintenance, and De-sulfication. It retains use of the OEM AC breakers and the DC fuse panel. $213 for the kit, as I type.
Kept the one replaced and carry it with me in the trailer. Should for some strange reason, the PD die, I could do "surgery" in the field until a permanent correction was made.
44,060 PostsLatest Activity: Mar 28, 2026
