SidecarFlip wrote:
My WFCO has been just fine. I must have a prototype model..... lol It's getting a PD upgrade this winter just because I have no trust in it.
I guess I must have got the sister prototype unit that you did Flip. My WFCO has also been fine. It goes to over 14V only if the battery has been run quite low. Otherwise it just goes to 13.6, then after about 24 hours, drops to 13.0 to 13.2.
I picked up my trailer on Nov 15, 2011. I watched the guy at the dealership put the AGM battery on the tongue. The same battery is still there....charged by the WFCO, and still holds a charge fine.
At times it's on for months at a time, like when I am parked in AZ for the winter. At other times, it sits for a few weeks to a few months at a time with no shore power hooked to it.
If I did a lot of boondocking, I might have had different results. Also, if I would have done boondocking, I would have approached the whole thing differently, as in, I would have had two batteries and solar.
PS, I did put a battery disconnect switch at the battery box so I can totally disconnect it while it sits at home w/o the shore power connected.
