Ron_Gratz
Mar 22, 2014Explorer
outwestbound wrote:The TT with the higher GVWR should be safer -- but not necessarily due to a stronger brake system.
If a travel trailer's load (all my cargo, liquids, batts, LP, etc.)PLUS dry trailer weights were hypothetically say 8,200lbs for two TTs I'm considering, but the GVWR on one was 9800 and the other 11,000, wouldn't the higher GVWR be the safest? Ignoring cost, wouldn't the TT with the highest GVWR, even if I don't need to put more cargo in it, essentially be safer due to stronger brake system?
The two TTs (9800# GVWR and 11000# GVWR) could be using the same brakes.
But, if they have the same brakes and different GVWRs, the GVWR of the 9800# TT must be limited by something other than its brakes -- perhaps its tires.
So, lets assume the 9800#-rated TT has brakes rated for 12000# and tires rated for 9800#.
And, let's assume the 11000#-rated TT has brakes rated for 12000# and tires rated for 11000#.
Under these assumptions, it boils down to whether it's "safer" to operate at 84% of tire rating and 68% of brake rating (with the lower GVWR) or at 75% of tire rating and 68% of brake rating (with the higher GVWR).
Since the GVWR is supposed to be based on the "weakest" component of the tire/brake/axle/suspension/frame system, I always would opt for the trailer which has the higher GVWR.
Ron
44,070 PostsLatest Activity: Aug 05, 2026
