JJBIRISH
Mar 22, 2014Explorer
mich800 wrote:JJBIRISH wrote:
First the question is about the rating not the total load…
anyone that thinks the lighter load rating is a good thing is out of their cotton picking mind…
There is more to it than just the brakes… there is the springs axle and chassis that allow for the additional load rating… and that is a good thing under any circumstances, and I can’t think of any reason that a higher CCC is somehow a bad idea…
There is a lot of marketing with these things but what is being marketed here is someone has a trailer with a light CCC so thinks everyone else should…
I don't think that is the question. The question is: Is the TT with less unused capacity less safe then one with more unused capacity? I do not see how this can be answered. Both are safe.
Or put another way; is a one ton truck safer than a half ton truck? The one ton has a higher payload capacity.
mich,
I still read the question as 2 trailers each with a specific and different GVWR and both with a same but hypothetically GVW (8200 pounds)… I think my comprehension was on target as to the question..
My answer and my opinion is as it was…
there would be no basis to determine the trailer vehicle with the lighter GVWR and lower CCC would be better or safer…
and by the same token there is a basis to believe and determine that the trailer with the higher GVWR and higher allowable CCC is a better choice and has a greater margin (higher safe load capacity) for safety…
What I never said is one is safe and the other is not..., which was not the question and which is what you are implying I said… there are reasons for the higher GVWR, and we just don’t know at this point what they are…
To answer your question,
“is a one ton truck safer than a half ton truck? The one ton has a higher payload capacity.”
Both are safe to their limit, but the one tone with its higher payload capacity is safer for a wider range of applications… so yes the 1 ton could be a safer vehicle by virtue of having heavier axles bigger brakes and heavier tires and a higher capacity… especially if it was purchased to haul weight loads…
Would it be a more comfortable ride to use for a daily driver??? Most likely it would not…
A trailer chassis sole purpose is designed to carry loads…
But if I am wrong it wouldn’t be the first time…
44,070 PostsLatest Activity: Aug 06, 2026
