Lowsuv
Mar 23, 2014Explorer
regarding f150 vs f250 :
F250 has 4 very large disk brakes .
While at the tire store you can observe the significant difference in size of the calipers and the disks of the f250 vs f150 .
While checking these rigs on the rack compare the size of the rear axle "bajo" of the F250 vs the punier F150 .
Take a look at the universal joints and the size of the driveline while you are doing the comparison . Once again F250 .
The size of the frame is larger on the F250 also .
The rear axle payload of the F250 is significantly higher on the F250 .
This allows one to load the tongue weight up on the trailer being towed .
Higher tongue weight eliminates trailer sway .
The F150 has a more limited payload and the trailer tongue cannot be loaded as heavy . This makes for a higher percentage of uncontrolled weight behind the trailer axle . This adds to sway .
The f150 might have the lighter weight eco-boost engine . This takes weight off of the steering wheels of the F150 .
The F250 is frequently sold with a diesel engine . This adds 400+ pounds to the front end weight over a V8 gasser . Possibly 600 more pounds on the front end than a V6 in the F150 .
For towing it is always better to tow a 7000 # trailer with a pickup that weighs 7000# rather than a pickup that weighs 6200 # .
