yankeeslover's avatar
yankeeslover
is it hard for a novice to repack bearings???
im lost with this. 2011 featherlite 17.. im not sure if the bearings have ever been done. im no mechanic and don't pretend to be.LOL. is this a simple diy job or a job for a rv place to handle? Im assuming after 2-3 years that I should have them redone? if this is an easy job to do myself how is this done? the previous owner gave me all the manuals that came with camper but I couldn't seem to find anything on the bearings.... thank you for the help....
  • rv place charges $95.00...maybe I should just pay them? small fee if only every couple years to do? or are rv dealers known to find other troubles?
  • If you have worked on vehicles, know how to use tools, jacks and jack stands it's not hard. If you don't then I would have a mechanic do it.
    I'm sure there are videos posted on YouTube showing how to pack wheel bearings.
    The toughest part for a novice will be getting the bearings seated and tightened properly when you put it all back together.
    Some bearings and grease last a lifetime so you may not need to pack them. The owners manual should show a maintenance schedule.
  • first time ? better to have a friend who knows show you. its not hard BUT things have to go back in the right spot and the nut tension needs to be just right.
  • Here is a basic guide: for Ez Lube hubs. But, I recommend hand packing over this but, it's much more involved. I guess you can decide if you want to tackle a bearing repack...it is messy.
    LINK
