mike-s
Oct 07, 2016Explorer II
Sam Spade wrote:Yep. Most monitors are setup with 3 sensors, at 1/4, 1/2, and 3/4 levels. When the level reaches them, the monitor shows 1/3, 2/3 and full. So, when they first show full, you're only at 3/4. That's to give some leeway (if the tank isn't level) and warning before it's really full.
OR you are believing a status light that is indicating FULL a lot sooner than is true.
And, that's all assuming that they put the sensors in accurately.
But still, over 10 gallons per day into the gray water tank indicates a lack of conservation.
Don't do dishes 3 times a day, save up and do them once a day. A gallon for wash and a gallon for rinse x3 is 6 gallons/day right there. If the sink is being filled even half way, it's likely much more than a gallon for each, and if everything is scraped clean beforehand, 1/2 gallon each for wash/rinse is possible.
Should be able to brush teeth with 1/2 cup (literal "cup") of water vs. a quart or more if using the faucet. Don't wash hands under the faucet - close the drain and fill the sink with a cup or two of water, hands wet then wash with a bit of soap, rinse off with the sink water.
Never let fresh water go down the drain, the drain should be closed anytime the tap is open - fresh down the drain is a total waste.
OH48Lt wrote:Uh, OP:"grey water tank...we were filling up the tank every two days..."
Is the fresh water tank really running dry?
I'm guessing they may even have had a water (but not sewer) hookup.
44,068 PostsLatest Activity: Jun 21, 2026
